PCIe Gen2 on Cyclone V GT FPGA Dev Kit
Hi Vijay,
I seeing your ltssm is stuck at 00h which is in detect.quiet stage.
This mostly happen due to the host Can't detect far end Receiver.
I suggest to check with the Connectivity problem or Board component problem/
- Is this plug in to slot that supported gen2 ?
- do you change the BIOS setting from "auto" to "gen2"
- Please check your VCCR/VCCT , ensure that it is 1.1v
Wincent_Altera
Wincent,
The board is plugged into gen4 pcie slot.
Regarding the pin assignments,
The Board reference manual recommends PCML for the serdes pins.
We are currently using this setting
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_instance_assignment -name IO_STANDARD LVDS -to clk_clk
set_instance_assignment -name IO_STANDARD HCSL -to dut_refclk_clk
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to dut_npor_pin_perst
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_rx_in0
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_rx_in1
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_rx_in2
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_rx_in3
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_tx_out0
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_tx_out1
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_tx_out2
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to dut_hip_serial_tx_out3
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
