Steve-Mowbray-ENL's avatar
Steve-Mowbray-ENL
1 year ago
Passive serial versus active serial configuration -- swap using Convert Programming Files utility
Hi
Probably a dumb question but can the configuration method be managed using the Quartus "Convert Programming Files" utility for instance:
  • Quartus project Device and Pins Configuration Scheme = ASx1 :: can generated SOF image be converted to properly functional passive serial RBF image using Convert Programming Files?
  • Quartus project Device and Pins Configuration Scheme = PS :: can generated SOF image be converted to properly functional active serial JIC image using Convert Programming Files?
This would save constantly changing Quartus project device and pin assignments (and rebuilding) according to the configuration method selected...
Steve
  • Hello,
    Basically, yes, you can use the same .sof file and convert to AS or PS programming files.
    regards,
    Farabi
  • FakhrulA_altera's avatar
    FakhrulA_altera
    I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
  • Farabi_Altera's avatar
    Farabi_Altera
    regards,
    Farabi
    • Steve-Mowbray-ENL's avatar
      Steve-Mowbray-ENL
      Hi Farabi
      Quick update with some results for posterity:
      • JIC files always same size regardless of generated from active or passive serial SOF files...
      • passive serial RBF files generated from active serial SOF files are approximately twice as big as passive serial RBF files generated directly by Quartus -- not sure why this would be but means is more attractive to make the default build passive serial
      • I have programmed a platform with a JIC converted from passive serial SOF and it has programmed and runs correctly with MSEL pins set to active serial configuration mode...
      Steve
      Steve-Mowbray-ENL
      Thanks Farabi
      That is good news and will save some effort managing configuration method between old and new target systems
      Steve
