Steve-Mowbray-ENL's avatar
Steve-Mowbray-ENL
1 year ago
Passive serial versus active serial configuration -- swap using Convert Programming Files utility
Hi Probably a dumb question but can the configuration method be managed using the Quartus "Convert Programming Files" utility for instance: Quartus project Device and Pins Configuration Scheme = ...
  • Farabi_Altera's avatar
    1 year ago
    Basically, yes, you can use the same .sof file and convert to AS or PS programming files.
    regards,
    Farabi
