Steve-Mowbray-ENL
1 year agoPassive serial versus active serial configuration -- swap using Convert Programming Files utility
Hi Probably a dumb question but can the configuration method be managed using the Quartus "Convert Programming Files" utility for instance: Quartus project Device and Pins Configuration Scheme = ...
- 1 year ago
Basically, yes, you can use the same .sof file and convert to AS or PS programming files.
regards,
Farabi
Farabi_Altera
1 year agoHello,
regards,
Farabi
- Steve-Mowbray-ENL1 year ago
Hi Farabi
Quick update with some results for posterity:
- JIC files always same size regardless of generated from active or passive serial SOF files...
- passive serial RBF files generated from active serial SOF files are approximately twice as big as passive serial RBF files generated directly by Quartus -- not sure why this would be but means is more attractive to make the default build passive serial
- I have programmed a platform with a JIC converted from passive serial SOF and it has programmed and runs correctly with MSEL pins set to active serial configuration mode...
Steve
Thanks Farabi
That is good news and will save some effort managing configuration method between old and new target systems
Steve
