Tom16
3 years agoParametric phase delay fpga quartus
I want to generate multiple signals, and they must be phase shifted. The every phase would be calculated and have to be insert in automatically. I think about using parameters, but I don't now exactly...
AGORS5
3 years agoSo divide it.
Use PLL to generate MHz signal and dived it to khz signal.
Use PLL dynamic phase shift to control kHz phase shift. Taaadaaaa.
Tom16
3 years agoYeah but I if you divide it by counter - any phase shift on MHz signal would be negligible kHz shift. I need it to be significant. Altpll_reconfig isn't available, if it is what you meant.
