Mikexx
1 year agoI presume the signals are not terminated? I would also keep an open mind over the integrity of measurement in terms of probe and 'scope. Do you have a reference signal on the board to compare with?
Do you really mean either 8 or 4 Amps? How are you measuring this current? Can you elaborate on the context of this current?
Is the Max10 device output limited by protection diodes that don't clam to your 3.3V VCC? In which case 4.7V is quite realistic on account of a reflection. How long is the trace?
Does the Max10 have an internal source resistance capability? Can you load the PWM output at the signal destination?
