14 years agoOutput voltage doesn't match settings
Hello! I'm using altera cyclone II DE1 EP2C20F484C7. I've set default I/O to 1.8V, set ALL I/O bank's Vccio to 1.8V. Also I'm using expansion slot. Then I have measured voltage on expansion he...
14 years agoPlacing a schottky diode of sufficient current capability instead of the jumper R30 to reduce VCCIO to about 3.0V should work.
