14 years agoOutput voltage doesn't match settings
Hello! I'm using altera cyclone II DE1 EP2C20F484C7. I've set default I/O to 1.8V, set ALL I/O bank's Vccio to 1.8V. Also I'm using expansion slot. Then I have measured voltage on expansion he...
14 years ago --- Quote Start --- I work on student project - UICC terminal on DE1. Simple sim cards have several operation mode - class c (1.8v) and class b (3.3), but specification says that 3.3V is maximum, so I think I must lower voltage to, say, 3.2V for better compatibility with 3.3V sim cards. It would be easier, than implement level translator for class c operation mode. --- Quote End --- There are dual-power-rail level translators from Texas Instruments and others. On one side you power it at 3.3V from the DE1 expansion header, and interface at 3.3V, and then on the other side, you power it from 1.8V or 3.2V for interfacing to the sim card. You're going to need a socket anyway, so you may as well put the buffer in there too. You might even find a sim card PCB assembly with the connector and the level translators. Take a look on the web and see if you can find something. Cheers, Dave
