14 years agoOutput voltage doesn't match settings
Hello! I'm using altera cyclone II DE1 EP2C20F484C7. I've set default I/O to 1.8V, set ALL I/O bank's Vccio to 1.8V. Also I'm using expansion slot. Then I have measured voltage on expansion he...
14 years agoI work on student project - UICC terminal on DE1. Simple sim cards have several operation mode - class c (1.8v) and class b (3.3), but specification says that 3.3V is maximum, so I think I must lower voltage to, say, 3.2V for better compatibility with 3.3V sim cards. It would be easier, than implement level translator for class c operation mode.
And thank you, again. Great community I've found here.
