14 years agoOutput voltage doesn't match settings
Hello! I'm using altera cyclone II DE1 EP2C20F484C7. I've set default I/O to 1.8V, set ALL I/O bank's Vccio to 1.8V. Also I'm using expansion slot. Then I have measured voltage on expansion he...
14 years ago --- Quote Start --- Ok, so I will connect resistors to lower voltage, I think --- Quote End --- A resistive divider should be ok if you are driving a signal from the DE1 to the 1.8V logic, however, the 1.8V logic will not be able to drive a valid high back to the 3.3V logic. For that, you need a level translator. If you were designing your own FPGA board, then you could power a VCCIO bank at 1.8V and connect it directly to your 1.8V logic. However, the DE1 does not provide a 'simple' way of changing the VCCIO. I did notice that there was a jumper from VCC33 to VCCIO. You could remove that and power VCCIO from 1.8V, but since there is already logic on that power rail, the other components would stop working (which you might not care about). Cheers, Dave
