TSchu3
1 year agoOutput raw high speed signal to SMA
Hello all, I have a test design with a simple ring oscillator. I want to measure its freq. externally with an oscilloscope. I want to export this signal to an SMA connector (single or differential...
WZ2
1 year agoHi there,
Thanks for sharing the context.
Just to better understand your setup—how did you implement the ring oscillator in your design?
Also, what is the expected output frequency range of the oscillator? This might help determine whether GPIO is sufficient or if another solution is needed for reliable observation.
Looking forward to your input.
WZ
