14 years agoOutput Pin Driving Another Output Pin
Hello all, I've run into an unusual problem. I'll start off by describing my goal: I'm designing a circuit that can test for short circuits and open circuits in a wiring harness. The wiring har...
14 years ago --- Quote Start --- How does this look? Is this what you suggested? --- Quote End --- No need for the 5k resistor connected to +12V on the left. The one on the right is enough. Another remark: why do you use an additional +5V supply on the right? Use 3.3V here too. If it's just a matter of MOSFET threshold, select a transistor with lower Vgs. --- Quote Start --- One thing that bothers me is this: I will need the circuit to have 300 IO traces. If I put a transistor on each end and on each trace, I will need 600 transistors per board. Don't you think this is too excessive? --- Quote End --- Those transistors and resistors don't make a great difference: those are small components. Remind you already have to place 300 traces and 300 connectors with wires, which make a more bulky (and costly) hardware.
