Output enables on MAX7000s
I'm working with a MAX7128S device. Internally, I have an output enable driving some outputs as follows:
assign PIN_13 = (!oe_n) ? ab : 1'bz;
assign PIN_15 = (!oe_n) ? ab : 1'bz;
assign PIN_16 = (!oe_n) ? ab : 1'bz;
assign PIN_17 = (!oe_n) ? ab : 1'bz; etc... Externally I see that there are a couple of global output enable pins available. I tied them low to enable them all of the time. When I look out my outputs, I can see that they are active all of the time.. even when oe_n is high. AM I missing something with respect to how the output enable function works with these devices? I thought that it was a function of the internal and output enable signals that drive the outputs. No? (I.E. internal OE signal must be active AND external OE signal must be active)6 Replies
The OE function in the above code isn't related to global OE because it doesn't use an unconditional OE function for any output.
Hi, I had a similar issue a while back and this is the response I received from altera:
"Thank you for using Altera mySupport. Regarding your query, please refer to Max 7000 device handbook and the Pin-out. If you would like to use global output enable, just connect the register OE to the OE input pin (OE1 and OE2 in pinout)." I asked some follow up questions and this is the second response: "Let me clarify my previous reply at below. [Q1]: My question is whether there is a way to do this without using logic in my code. The OE register you mentioned in your response has to be declared in my code like a standard register, right? And then used in my code to enable my output? [A1]: Yes, you are right. However, you can run simulation and analysis to confirm. Alternatively, you can actually consider to instantiate a tri - state buffer block. [Q2]: So basically, according to the last sentence, the OE input is of no special use in MAX 7000 devices if I am using Quartus? [A2]: Yes, the Fast Output Enable Register logic option is not available for MAX 7000 devices supported by the Quartus II software." - Altera_Forum
Is there something I need to do in Quartus to tell the tool how I want to enable/disable the ouputs, or configure the global OE pins?
No idea why OE function is not working. Did you check the drivers in simulation? The code synthesises without any serious warnings in Quartus.
Here' the rest of the module:
The logic appears to be working great.. the only problem is that the outputs are enabled all of the time.`timescale 1 ns/1 ps module Custom_09xx ( // Header for debugging on the FPGAArcade Custom Device PIN_1 , PIN_2 , PIN_3 , PIN_4 , PIN_5 , PIN_6 , PIN_7 , PIN_8 , PIN_9 , PIN_10 , PIN_11 , PIN_12 , PIN_13 , PIN_15 , PIN_16 , PIN_17 , PIN_18 , PIN_19 , PIN_20 , PIN_21 , PIN_22 , PIN_23 , PIN_24 , PIN_25 , PIN_26 , PIN_27 ); //============================================================================= // I/O //============================================================================= input PIN_1; // not connected input PIN_2; // not connected input PIN_3 ; // H2 input PIN_4 ; // HSYNC input PIN_5 ; // HRESET input PIN_6 ; // VRESET input PIN_7 ; // VSH8 input PIN_8 ; // VSH7 input PIN_9 ; // VSH6 input PIN_10 ; // VSH5 input PIN_11 ; // VSH4 input PIN_12 ; // VSH3 output PIN_13 ; // AB1 // input PIN_14; // GND output PIN_15 ; // AB2 output PIN_16 ; // AB3 output PIN_17 ; // AB4 output PIN_18 ; // AB5 output PIN_19 ; // AB6 output PIN_20 ; // AB7 output PIN_21 ; // AB8 output PIN_22 ; // AB9 output PIN_23 ; // AB10 output PIN_24 ; // AB11 output PIN_25 ; // AB12 input PIN_26 ; // VDD output PIN_27 ; // not connected // input PIN_28; // not connected //============================================================================= // Parameters //============================================================================= parameter COUNT1 = 1'b0; parameter COUNT2 = 1'b1; //============================================================================= // Internal wires/registers //============================================================================= wire H2; wire hsync_n; wire hreset_n; wire vreset_n; wire vsh; wire ab; wire ab1; wire ab2; reg count1_4_0; wire count1_4_0_nxt; wire count1; wire count2_3_0; wire count2_11_4_nxt; reg count2_11_4; wire count2; reg loop_cnt; reg loop_cnt_nxt; reg hsync_count_7_0; wire hsync_count_7_0_nxt; wire hsync_count; reg count_sel; wire count_sel_nxt; wire oe_n; reg hreset_prev; reg vreset_sync; reg hreset_sync; //============================================================================= // Implementation //============================================================================= // assign inputs assign H2 = PIN_3; assign hsync_n = PIN_4; assign hreset_n = PIN_5; assign vreset_n = PIN_6; assign vsh = {PIN_7,PIN_8,PIN_9,PIN_10,PIN_11,PIN_12}; // synchronize reset signals always @(posedge H2 or negedge vreset_n) begin if (!vreset_n) vreset_sync <= 1'b0; else vreset_sync <= vreset_n; end always @(posedge H2 or negedge hreset_n) begin if (!hreset_n) hreset_sync <= 1'b0; else hreset_sync <= hreset_n; end always @(posedge H2 or negedge hreset_n) begin if (!hreset_n) hreset_prev <= 1'b0; else hreset_prev <= hreset_n; end // mux select to switch between count1 and count2 and control when they increment always @(posedge H2) begin if (!vreset_sync) count_sel <= COUNT2; else count_sel <= ~count_sel; end // count1 logic assign count1_4_0_nxt = (!hreset_sync) ? 5'd0 : (!vreset_sync) ? 5'd6 : (count1_4_0 == 5'h1F) ? 5'd0 : count1_4_0 + 5'd1; always @(posedge H2) begin if (count_sel == COUNT1) count1_4_0 <= count1_4_0_nxt; end assign count1 = {7'b0100000,count1_4_0}; // count2 logic. // least significant nibble seems to track with hsync_count. assign count2_3_0 = hsync_count; assign count2_11_4_nxt = (count_sel || !hreset_prev) ? count2_11_4 : (ab2 === 8'hBF) ? count2_11_4 - 8'h3F : count2_11_4 + 8'd1; always @(posedge H2 or negedge hreset_n) begin if (!hreset_n) begin count2_11_4 <= 8'h80; end else begin count2_11_4 <= count2_11_4_nxt; end end assign count2 = {count2_11_4,count2_3_0}; // hsync count logic. Increments by 1 every hsync interval. assign hsync_count_7_0_nxt = hsync_count_7_0 + 8'd1; always @(negedge hsync_n or negedge vreset_n) begin if (!vreset_n) hsync_count_7_0 <= 8'd0; else hsync_count_7_0 <= hsync_count_7_0_nxt; end assign hsync_count = {4'h3,hsync_count_7_0}; assign ab2 = count2 + {2'b00,vsh,4'h0}; // vsh gets added to the middle nibble of count2 before it gets sent out assign ab1 = count1 + {4'h0,count2,5'h00}; // the last nibble of count gets added to the middle nibble of count1 before it gets sent out // mux to send out either of the 3 overall ab values assign ab = (~hsync_n) ? hsync_count : (count_sel) ? ab2 : ab1; // output enable assign oe_n = ~H2 | (~hsync_n & ~count_sel); // assign outputs assign PIN_27 = 1'bz; assign PIN_13 = (!oe_n) ? ab : 1'bz; assign PIN_15 = (!oe_n) ? ab : 1'bz; assign PIN_16 = (!oe_n) ? ab : 1'bz; assign PIN_17 = (!oe_n) ? ab : 1'bz; assign PIN_18 = (!oe_n) ? ab : 1'bz; assign PIN_19 = (!oe_n) ? ab : 1'bz; assign PIN_20 = (!oe_n) ? ab : 1'bz; assign PIN_21 = (!oe_n) ? ab : 1'bz; assign PIN_22 = (!oe_n) ? ab : 1'bz; assign PIN_23 = (!oe_n) ? ab : 1'bz; assign PIN_24 = (!oe_n) ? ab : 1'bz; assign PIN_25 = (!oe_n) ? ab : 1'bz; endmodule - Altera_Forum
In MAX7128S, output enable can be driven by dedicated nOE inputs or macro cells. Your code is supposes to work, if oe_n is defined accordingly. This can't be seen from your post.
