14 years agoOutput enables on MAX7000s
I'm working with a MAX7128S device. Internally, I have an output enable driving some outputs as follows: assign PIN_13 = (!oe_n) ? ab : 1'bz;
assign PIN_15 = (!oe_n) ? ab : 1'bz;
assign ...
14 years agoHere' the rest of the module:
`timescale 1 ns/1 ps
module Custom_09xx
// Header for debugging on the FPGAArcade Custom Device
PIN_1 ,
PIN_2 ,
PIN_3 ,
PIN_4 ,
PIN_5 ,
PIN_6 ,
PIN_7 ,
PIN_8 ,
PIN_9 ,
PIN_10 ,
PIN_11 ,
PIN_12 ,
PIN_13 ,
PIN_15 ,
PIN_16 ,
PIN_17 ,
PIN_18 ,
PIN_19 ,
PIN_20 ,
PIN_21 ,
PIN_22 ,
PIN_23 ,
PIN_24 ,
PIN_25 ,
PIN_26 ,
PIN_27
// I/O
input PIN_1; // not connected
input PIN_2; // not connected
input PIN_3 ; // H2
input PIN_4 ; // HSYNC
input PIN_5 ; // HRESET
input PIN_6 ; // VRESET
input PIN_7 ; // VSH8
input PIN_8 ; // VSH7
input PIN_9 ; // VSH6
input PIN_10 ; // VSH5
input PIN_11 ; // VSH4
input PIN_12 ; // VSH3
output PIN_13 ; // AB1
// input PIN_14; // GND
output PIN_15 ; // AB2
output PIN_16 ; // AB3
output PIN_17 ; // AB4
output PIN_18 ; // AB5
output PIN_19 ; // AB6
output PIN_20 ; // AB7
output PIN_21 ; // AB8
output PIN_22 ; // AB9
output PIN_23 ; // AB10
output PIN_24 ; // AB11
output PIN_25 ; // AB12
input PIN_26 ; // VDD
output PIN_27 ; // not connected
// input PIN_28; // not connected
// Parameters
parameter COUNT1 = 1'b0;
parameter COUNT2 = 1'b1;
// Internal wires/registers
wire H2;
wire hsync_n;
wire hreset_n;
wire vreset_n;
wire vsh;
wire ab;
wire ab1;
wire ab2;
reg count1_4_0;
wire count1_4_0_nxt;
wire count1;
wire count2_3_0;
wire count2_11_4_nxt;
reg count2_11_4;
wire count2;
reg loop_cnt;
reg loop_cnt_nxt;
reg hsync_count_7_0;
wire hsync_count_7_0_nxt;
wire hsync_count;
reg count_sel;
wire count_sel_nxt;
wire oe_n;
reg hreset_prev;
reg vreset_sync;
reg hreset_sync;
// Implementation
// assign inputs
assign H2 = PIN_3;
assign hsync_n = PIN_4;
assign hreset_n = PIN_5;
assign vreset_n = PIN_6;
assign vsh = {PIN_7,PIN_8,PIN_9,PIN_10,PIN_11,PIN_12};
// synchronize reset signals
always @(posedge H2 or negedge vreset_n) begin
if (!vreset_n)
vreset_sync <= 1'b0;
else
vreset_sync <= vreset_n;
end
always @(posedge H2 or negedge hreset_n) begin
if (!hreset_n)
hreset_sync <= 1'b0;
else
hreset_sync <= hreset_n;
end
if (!hreset_n)
hreset_prev <= 1'b0;
else
hreset_prev <= hreset_n;
end
// mux select to switch between count1 and count2 and control when they increment
always @(posedge H2) begin
if (!vreset_sync)
count_sel <= COUNT2;
else
count_sel <= ~count_sel;
end
// count1 logic
assign count1_4_0_nxt = (!hreset_sync) ? 5'd0 :
(!vreset_sync) ? 5'd6 :
(count1_4_0 == 5'h1F) ? 5'd0 : count1_4_0 + 5'd1;
if (count_sel == COUNT1)
count1_4_0 <= count1_4_0_nxt;
end
assign count1 = {7'b0100000,count1_4_0};
// count2 logic.
// least significant nibble seems to track with hsync_count.
assign count2_3_0 = hsync_count;
assign count2_11_4_nxt = (count_sel || !hreset_prev) ? count2_11_4 :
(ab2 === 8'hBF) ? count2_11_4 - 8'h3F : count2_11_4 + 8'd1;
if (!hreset_n) begin
count2_11_4 <= 8'h80;
end else begin
count2_11_4 <= count2_11_4_nxt;
end
end
assign count2 = {count2_11_4,count2_3_0};
// hsync count logic. Increments by 1 every hsync interval.
assign hsync_count_7_0_nxt = hsync_count_7_0 + 8'd1;
always @(negedge hsync_n or negedge vreset_n) begin
if (!vreset_n)
hsync_count_7_0 <= 8'd0;
else
hsync_count_7_0 <= hsync_count_7_0_nxt;
end
assign hsync_count = {4'h3,hsync_count_7_0};
assign ab2 = count2 + {2'b00,vsh,4'h0}; // vsh gets added to the middle nibble of count2 before it gets sent out
assign ab1 = count1 + {4'h0,count2,5'h00}; // the last nibble of count gets added to the middle nibble of count1 before it gets sent out
// mux to send out either of the 3 overall ab values
assign ab = (~hsync_n) ? hsync_count :
(count_sel) ? ab2 : ab1;
// output enable
assign oe_n = ~H2 | (~hsync_n & ~count_sel);
// assign outputs
assign PIN_27 = 1'bz;
assign PIN_16 = (!oe_n) ? ab : 1'bz;
assign PIN_17 = (!oe_n) ? ab : 1'bz;
assign PIN_18 = (!oe_n) ? ab : 1'bz;
assign PIN_19 = (!oe_n) ? ab : 1'bz;
assign PIN_20 = (!oe_n) ? ab : 1'bz;
assign PIN_21 = (!oe_n) ? ab : 1'bz;
assign PIN_22 = (!oe_n) ? ab : 1'bz;
assign PIN_23 = (!oe_n) ? ab : 1'bz;
assign PIN_24 = (!oe_n) ? ab : 1'bz;
assign PIN_25 = (!oe_n) ? ab : 1'bz;
endmodule
The logic appears to be working great.. the only problem is that the outputs are enabled all of the time.
