16 years agoOpenCores MAC
Hello! How the app (with Nios Software Tools) must be created to work with the open cores mac in superloop mode? do I need to use superloop_tse library? In the OCM doc says its's possible, bu...
16 years agoHello!
The project it's working right now :). I have it working with NSBT 9.1 and the socket_server works correctly. There is something you could add to your documentation: You use the macro ALT_CPU_FREQ in the file ins_eth_ocm.c in, which must be modified to the module frequency when it's operating at a difefrent speed than the CPU. Oh and there are no so big hacks, just adding a few lines to create-this-bsp and create-this-app to make it work. I'm docuemnting this at, then will I post them. Thanks for the help! Bye!
