16 years agoOpenCores MAC
Hello! How the app (with Nios Software Tools) must be created to work with the open cores mac in superloop mode? do I need to use superloop_tse library? In the OCM doc says its's possible, bu...
16 years agoThe error is confusing. Your BSP should not be compiling in the "altera_avalon_tse" driver if you are using the OpenCores MAC. Are you using someone else's BSP? I'm guessing that the Superloop SSS example used the TSE MAC instead of the OpenCores MAC.
Jake
