15 years agoOpencore CAN 2.0 Avalon Interface
Please I intend to add a custom component (opencore CAN 2.0B) but I am concerned with the type of Avalon Bus I should use for that: Avalon Memory Mapped Interface (Avalon-MM) or Avalon Memory Mapped Tristate Interface I would appreciated any advices. Regards,4 Replies
Please any design guideline to test my CAN interface(CPU+RAM+.......)?
http://www.alteraforum.com/forum/L:\Internship\FPGA_Cyclone IV\Implementation\CAN\can_controller.png - Altera_Forum
You are right.
You must accomplish two steps : - write a simple wrapper code to convert Wishbone to Avalon - create the sopc builder component - Altera_Forum
Ok Chris,
I have seen what you means within the file can.defines:
As I intended to use Wishbone Interface:So I just have to use the Memory Mapped Slave Interface and the same Glue Logic formel as mentioned on the wiki site. Am I wrong? Regards,// Uncomment following line if you want to use WISHBONE interface. Otherwise // 8051 interface is used. // `define CAN_WISHBONE_IF - Altera_Forum
You can do either.
The CAN component available on OpenCores website, can be configured for Wishbone bus or standard 8051 bus interface. Wishbone can be easily connected to Avalon MM with minimal glue logic. Same for 8051 bus to tristate bus.
