15 years agoOpencore CAN 2.0 Avalon Interface
Hi, Please I intend to add a custom component (opencore CAN 2.0B) but I am concerned with the type of Avalon Bus I should use for that: Avalon Memory Mapped Interface (Avalon-MM) or Aval...
15 years agoOk Chris,
I have seen what you means within the file can.defines:
// Uncomment following line if you want to use WISHBONE interface. Otherwise
// 8051 interface is used.
// `define CAN_WISHBONE_IF
As I intended to use Wishbone Interface:So I just have to use the Memory Mapped Slave Interface and the same Glue Logic formel as mentioned on the wiki site. Am I wrong? Regards,
