16 years ago
one problem in simulate IP core.(SDRAM controller)
Hi,everybody.
I creat a new project. And create a sdram controller with the plug-in manager. At last, the manager create a new subfolder named "testbench" . and there is a vhdl file(**_tb.vhd) in it.
I want to simulate the design. But, when I create the waveform file, I cannot find the nodes in **_tb.vhd with node finder. In the dialog box "select hierarchy level", there are only the main project But no component in the new subfolder "testbench". And the **_tb.vhd is the the new subfolder.
What can i do to find the nodes in **_tb.vhd?
thanks.
1 Reply
    you cannot use HDL test benches in Quartus II Simulator. you'll have to use ModelSim-Altera Starter Edition which is free to use an HDL test bench.
