16 years agoOne or more serdesses, that's the question
I'm building a system with 4 transmit channels, all carrying the same data. What would be the pros and cons of using one serdes and split the output to 4 channels (data and clock) or using a separate...
16 years agoWhat type of data and what's the data rate? How much distance are you running the data and over what medium? I assume you are using a fanout buffer of some kind to split the data.
Jake
