14 years agoobject assigned a value but never read - does this effect synthesis?
Hello, I have the following small module which is intended to store the value 0xFF in a register when a button is pressed.
module connector_test(button, txd);
input button;
output reg t...
14 years agoThanks for the reply - that's enlightening!
Unfortunately, after adding the synthesis attribute, the register is still not synthesized. Is there a setting in Quartus that needs to be enabled so that synthesis attributes are not ignored - or am I simply using this incorrectly? The new code is below:
input button;
output reg txd;
reg data /* synthesis syn_noprune */;
always @(button) begin
if(button==1'b0) begin
txd <= 1'b0;
data <= 8'hFF;
end
else begin
txd <= 1'b1;
data <= 8'b0;
end
end
endmodule
