Ibrahimkok
3 years agoNUMBERS OF SINGLE ENDED I/O OF EPCQ4ASI8N EPCQ-A
Hi there, How do I determine the number of single ended digital input/outputs of the FPGA EPCQ4ASI8N EPCQ-A? cannot find the number in the datasheet. Thanks
AqidAyman_Altera
3 years agoHi Ibrahim,
Thank you for reaching out Intel FPGA Community.
Yes, EPCQ4ASI8N is not an FPGA, but it is a serial configuration device for FPGA.
As refer to the datasheet, this device, specifically EPCQ4A, is only supports AS x1 only and not ASx4 configuration mode.
Hence, based on the device's pin information, they only have two I/O pins (DATA0, DATA1). You can refer to below link for more information:
Aqid
