sgannava's avatar
sgannava
2 years ago
Not able to generate hps_iws_handoff folder
Hi Team,
I have successfully created a project using Intel Quartus Pro 23.3. But I am not able to see any hps_iws_handoff folder. What could be the issue? Did I miss anything?
Sai
  • aikeu's avatar
    aikeu
    Hi sgannava,
    Do you have the file "fit_spl_fpga.its" in your directory inside path below?
    a10_example.qspi\a10_soc_devkit_ghrd\software\bootloader\u-boot-socfpga\board\altera\arria10-socdk
    And before that did you manage to build the Uboot?
    Aik Eu
  • sgannava's avatar
    sgannava
    Hi Aik,
    Yes, the .its file is present in the path.
    Anyway, I have resoved the issue by installing device-tree-compiler.
    I have followup question. Currently, I am following the steps mentioned in the documentation to get familiarized with things to some extent and build is in progress after I run the command bitbake-core-image-minimal . But where can I include my custom dts files?
    Sai
  • sgannava's avatar
    sgannava
    Hi Aik,
    I am following the same documentation to build my custom Linux image for Arria10 SoC development kit. While building Yocto Rootfs, I am facing oe_runmake error. I have attached the log as well.
    This is happening in the build process while compiling linux-socfpga-6.6+git package.
    I tried below steps as well
    step-1: bitbake -c cleanall linux-socfpga
    step-2: bitbake linux-socfpga
    But at step-2, again same issues.
    Any help would be appreciated.
    Sai
  • aikeu's avatar
    aikeu
    Hi sgannava,
    I will close the thread if no further question.
    Aik Eu
  • sgannava's avatar
    sgannava
    Hi Aik,
    I am able to build the image successfully by removing the linux-socfpga_6.6bb (which is causing the error) blindly following the steps mentioned in the documentation. But I have below questions
    1. Where can I include my custom device tree source files and re-build the image?
    2. Where can I make changes so that the image mounts to /mnt folder instead of /dev/mmcblk02
    Sai
  • aikeu's avatar
    aikeu
    Hi sgannava,
    You can change the device tree based on your board following the GSRD you have gitclone from Rocketboards. Search using "Socfpga_arria10" in the go to file and can see a list of board related device tree being use. Make the changes to the device tree and try to recompile again if it takes effect.
    For Uboot:
    https://github.com/altera-opensource/u-boot-socfpga
    For Linux Kernel:
    https://github.com/altera-opensource/linux-socfpga
    As for the mount image to different location. I am not so sure how.
    Anyway can consider open a new forum case for the question since the original question to your issue has been resolved.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi sgannava,
    Aik Eu
