11 years ago
Node instance "tcm_address_w_check" instantiates undefined entity
Hello.
I am using Quartus 13.1 and Qsys.
I can build my project using verilog, qsys and NIOS previously.
But I added the clock component at pll in qsys.
I had error at build of quartus (using verilog):
Error is "Node instance "tcm_address_w_check" instantiates undefined entity"
I can generate qsys whih have no error.
But building quartus had error.
I checked system contents in qsys, I can not find tcm_address.
I am appreciate, if you suggest this issue.
    Thank you for responding.
    I used Avalon_ATTPLL.
    I used Edit. At Output/Clock tab, I set c3 and c4 clock data.
    And I build the connection to dualport RAM at system components in qsys.
    "But I added the clock component at pll in qsys."
    Mind further elaborate on what does it referred to by adding clock at PLL?
    Check into the design hierarchy where it is being instantiated. You can trace the error in analysis&synthesis messages sequence.
