allenS1
4 years agoNo .sof file generated for F-Tile Example Design
I am trying to generate and compile an example design using F-Tile Ethernet Hard IP. I generated the design (Single instance of IP core) and selected the Agilex I-Series SOC Dev Kit as the target dev...
- 4 years ago
Hi Allen,
In case you're using the latest version of Quartus, the device that you're using is in Advance device support.
Compilation, simulation, and timing analysis support are provided for these devices. The compiler generates pinout information for these devices in this release, but does not generate programming files.
Kindly refer to below UG link, page 10 Table 5 Advance device support
Pavee
paveetirrasrie_Altera
4 years agoHi Allen,
Based on the error message, it looks like you're using advanced version of the device for your project.
I would suggest you to use the latest version of Quartus to resolve this issue or you may try to use other device.
Pavee
