12 years ago
no element generate when compiled
I compile a project everything is corrected but no element usage is generated , I have no idea at all , here attached my project file
1 Reply
    Look at the warnings:
    --- Quote Start ---
    Warning (10541): VHDL Signal Declaration warning at top.vhd(44): used implicit default value for signal "CLK_OUT_0" because signal was never assigned a value or an explicit default value. Use of implicit default value may introduce unintended design optimizations.
    Warning (10541): VHDL Signal Declaration warning at top.vhd(45): used implicit default value for signal "reset_n" because signal was never assigned a value or an explicit default value. Use of implicit default value may introduce unintended design optimizations.
    Warning (10541): VHDL Signal Declaration warning at top.vhd(51): used implicit default value for signal "wait_s" because signal was never assigned a value or an explicit default value. Use of implicit default value may introduce unintended design optimizations.
    Warning (10492): VHDL Process Statement warning at top.vhd(152): signal "fifo_empty" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
    Warning (10492): VHDL Process Statement warning at top.vhd(195): signal "fifo_empty" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
    Warning (10873): Using initial value X (don't care) for net "slwr_d_n" at top.vhd(48)
    Warning (10873): Using initial value X (don't care) for net "done_d" at top.vhd(50)
    --- Quote End ---
