16 years agoNIOS2 EDS 9.1 - Linking problem?
I really need some help. This might be a simple solution but I dont know how to fix it. Thanks, I am getting the following error messages when linking: Info: Linking sss_6_15...
16 years agoHi,
I had faced to this problem (Nios II 8.1). You are using Superloop InterNiche, aren't you ? In order to compile with "success", I modified in alt_iniche_*.c the functions that cause errors. I remember using ALT_CLOSE() instead of alt_close(). I mean I used some macros which are defined in Altera's include. Something like that. I think there are conflicts between your modified iniche's code and altera's code. My solution is a dirty one.
