17 years agoNios II to SRAM via Tri-State Bridge
Let's see how long it takes to get a 'good' answer to this question: :D Ok, I have a Nios II system (32-bit data width) connected to a single 16-bit SRAM through an Avalon Tri-State Bridge (th...
16 years agoHi, I had a quite similar problem in the following configuration.
- 16 bits SRAM on the board - Custom SRAM component in SOPC builder - cs, ws, oe, add, 16 bits data controlled by custom component - beh, bel stuck to 0 in VHDL - mapping of a0 => a1 in VHDL All was functional when I was using "run configuration as" but the NIOS didn't boot in stand alone mode (boot copying from FLASH to SRAM). I saw with Signal Tap that all accesses to SRAM during the boot were in 8 bits mode instead of 16 bits. The solution was to add the control of beh and bel by the SRAM custom component, because it was not able to recognize a 16 bits SRAM with the 16 bits data bus specification ! Hope this helps.
