17 years agoNios II to SRAM via Tri-State Bridge
Let's see how long it takes to get a 'good' answer to this question: :D Ok, I have a Nios II system (32-bit data width) connected to a single 16-bit SRAM through an Avalon Tri-State Bridge (th...
17 years agoAre you using the SoPC builder component "IDT71V416"? If so, your problem is that the component is only for a 32-bit wide interface. That component was used specifically for 4 development boards that used two of the IC's in parallel. What you need to do is create a custom tri-state component with a 16-bit wide data bus. No you don't need to write any VHDL. You just need to let SoPC builder know that your component is 16 bits wide.
Jake
