MK_ABQ
Contributor
4 years agoNIOS II Selection
I am working on a project with one of the requirements to receive some inputs from Host PC using Ethernet protocol. Planning to use Arria 10 series FPGA. Lets say if we use NIOS II soft cor...
- 4 years ago
The economy vs fast is basically "Power and cost sensitive" vs "high performance"
Regarding the versions:
https://www.intel.com/content/www/us/en/docs/programmable/683836/current/main-tab.html
Example design you can try is the simple socket server:
For reference:
EBERLAZARE_I_Intel
4 years agoHi,
Are you looking for design for Ethernet + Nios II using Arria 10?
MK_ABQ
Contributor
4 years agoHi,
Yes I am looking to use Ethernet (1G) + NIOS II using Arria 10. would like to know which NIOS II core will support 1G ethernet?. I understand there are three versions: economy, standard and fast. which version will support 1G Ethernet?
