MK_ABQ
Contributor
3 years agoNios II gen2 - core
I am very new to Nios. I have a reference project folder with Nios II gen2 core used in that, and along with report files, and codes. How will I know which version of Nios core ( economy or ...
KellyJialin_Goh
3 years agoHi,
For the previous explanation, this was the <ProjectName>_bsp directory and system.h file that I mentioned as you create a file on Eclipse.
and you should be able to see the fast/economy version using.
Kelly Jialin, GOH
MK_ABQ
Contributor
3 years agoHello Kelly,
Thanks for your swift and detailed response. I learned the project database I have is pretty old ( built with Quartus Version 13.0). The version.txt is not available either.
Eventually just opened using old quartus version and figured out the NIOS version.
