Nios II gen2 - core
Another alternative way is locate to the Quartus you downloaded on your disk. The file path will be: Your_local_disk/intelFPGA/Quartus_version_you_installed/nios2eds/version.txt
You should be able to see the version of the NIOS core you installed in the text file.
Thank you.
Kelly Jialin, GOH
For the previous explanation, this was the <ProjectName>_bsp directory and system.h file that I mentioned as you create a file on Eclipse.
and you should be able to see the fast/economy version using.
Kelly Jialin, GOH
- MK_ABQ3 years ago
Contributor
Hello Kelly,
Thanks for your swift and detailed response. I learned the project database I have is pretty old ( built with Quartus Version 13.0). The version.txt is not available either.
Eventually just opened using old quartus version and figured out the NIOS version.
