Nios II gen2 - core
Another alternative way is locate to the Quartus you downloaded on your disk. The file path will be: Your_local_disk/intelFPGA/Quartus_version_you_installed/nios2eds/version.txt
You should be able to see the version of the NIOS core you installed in the text file.
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh3 years ago
For the previous explanation, this was the <ProjectName>_bsp directory and system.h file that I mentioned as you create a file on Eclipse.
and you should be able to see the fast/economy version using.
Kelly Jialin, GOH
- MK_ABQ3 years ago
Contributor
Hello Kelly,
Thanks for your swift and detailed response. I learned the project database I have is pretty old ( built with Quartus Version 13.0). The version.txt is not available either.
Eventually just opened using old quartus version and figured out the NIOS version.
