16 years agoNIOS II first time user
Hi I am using NIOS II processor first time. Please help me with following questions. Goal: I am using signalTap to monitor output of my logic and my control values are being hard coded....
16 years agoHi Jake,
If I wanted use the clock directly from board to custom module. Do I have to select “clock_reset” or “conduit_end”. ? I have three clocks coming into custom block. If I am getting the following warning(in component editor), which means that ,I can only connect one clock externally and create other two clocks using PLLs (instantiate in my custom module) warning: clock_reset: signal clk appears 3 times (only once is allowed) I selected “conduit_end” for my control and status signals, which means that using NIOS II IDE, I am able to change the control values in real-time and read the status registers in real-time. Or Do I still need to connect the SignalTaps to monitor my status signals real-time? Thanks Guru
