16 years agoNIOS II first time user
Hi I am using NIOS II processor first time. Please help me with following questions. Goal: I am using signalTap to monitor output of my logic and my control values are being hard coded....
16 years agoHere is one more tutorial for you. This will teach you how to create custom components for SoPC builder.
http://www.altera.com/literature/hb/qts/qts_qii54007.pdf After that, if you still feel you need help, I would be glad to assist you. Basically there are two different methods to interfacing to custom logic: 1 - Make your custom logic an SoPC builder component that resides inside your SoPC system. This is the most common approach and is what you'll learn in the above tutorial. 2 - Export a portion of the avalon bus and connect it to your custom logic outside SoPC builder. Jake
