18 years agoNios II CPU and Firmware access Problem
About the application: We have a multichannel application. Each channel design is based on a Altera Cyclone FPGA, which includes an internal NIOS II processor and an external program 32bit ASRAM (asy...
18 years agoHi,
You are correct the Fast Output Register is the right way. But we already found out that the NIOS SOPC builder set those definitions on all ASRAM pins, so no additional delay can be spared inside the FPGA. The only solution we came up is degrading the Nios speed to 95MHz. thanks and regards, Menachem
