16 years ago
NIOS II C language about SDRAM IOWR & IORD function and fopen & fclose
Hi, I'm new about Quartus II & NIOS II.
I made hardware part using sopc builder (nios II cpu, sdram, on-chip mem,
jtag, sysid, and so on)
and composed c source code for software part.
I want to get right output data from 'printf' function
and test1.txt file from 'fopen, fprintf, fclose' function
,but i didn't get any right result.
How can I solve this problems?
=======================================================# include <stdio.h># include <unistd.h># include "system.h"
# define DEBOUNCE 10000
int main()
int input_data = 0x0001;
int output_data;
FILE *fp;
IOWR(SDRAM_0_BASE, 0, input_data);
output_data = IORD(SDRAM_0_BASE, input_data);
printf("output data = %d\n", output_data);
fp = fopen("C:\test1.txt", "w");
fprintf(fp, "%d", output_data);
fclose(fp);
return 0;
Thanks in advance.
    oh you are teddy80
    hi again.
    if you have UART(RS-232C)
    you can program on NiosII to send data from SDRAM.
    and your computer can get RS232C data some how like hyper terminal.
    RS232C is slow...
    there is several way. LAN / SD-Card / USB ...
    but many things are difficult after all.
    you need to learn more.
    UART is easy to use.
    I recommend biginer to use UART to read data from embedded system.
    see you and good luck
    --- Quote Start ---
    int main()
    long input_data1 = 0x0000000011111111;
    long input_data2 = 0x1010101010101010;
    long output_data1;
    long output_data2;
    IOWR(SDRAM_0_BASE, 0, input_data1);
    output_data1 = IORD(SDRAM_0_BASE, 0);
    printf("output data1 = %x\n", output_data1);
    IOWR(SDRAM_0_BASE + 1, 0, input_data2);
    output_data2 = IORD(SDRAM_0_BASE + 1, 0);
    printf("output data2 = %x\n", output_data2);
    return 0;
    --- Quote End ---
    I think it is not possible to perform 64 bit IOWR.
    If you want to write 64 bit data you have to split it up into 2*IOWR.
    Use IOWR twice.
    Or am I wrong here? NIOS is 32bit
    Teddy,
    0x prefix stands for hex number. One hex digit = 4bit !!!
    You must use 0b00101... to specify a binary number.
    Moreover, your 'long' data variables are actually 64bit long !
    You are getting the correct 32bit prints with %x format.
    If you want complete 64bit print you should use %lx or %llx
    If you want ram native 16bit data access, you should define variables as 'short'.
    Cris
    --- Quote Start ---
    if you know where is "c:\" on your board?
    when you just create CPU(NiosII)
    you don't have file-system
    you need to create file-system as well.( Linux, uC-OSII or by yourself).
    --- Quote End ---
    Hi again!
    Do you know how can I get from SDRAM data to my hard driver?
    My goal is to have binary data of txt file form...
    Thanks for your continuous concern.
    --- Quote Start ---
    Hi Teddy,
    Apart from the fopen issue, I'm concerned about the two R/W instructions:
    Problem 1:
    You are writing to address 0 and reading from address 1 (content of input_data) which has not been initialized.
    Maybe, you meant this:
    output_data = IORD(SDRAM_0_BASE, 0);
    Problem 2:
    Are you sure this part of sdram is not already used for anything else?
    Otherwise your IOWR would corrupt code or other data.
    Cris
    --- Quote End ---
    Thanks for your answer.
    I used 16bit input_data in c code and
    16bit SDRAM using SOPC Builder,
    but I got only 8bit output_data.
    Where is the problem?
    <result>
    output data1 = 11111111
    output data2 = 10101010
    int main()
    long output_data1;
    long output_data2;
    return 0;
    Hi teddy,
    --- Quote Start ---
    fclose(fp);
    --- Quote End ---
    Akira is right. You need a filesystem for that.
    But as Cris mentioned, I am also concerned about the IOWR/IORD-part.
    If I got you right, you want to write input_data to some SDRAM-address and read it back for printing it.
    First: I would let the compiler allocate memory for you, unless you know what is at the specified address. You can use malloc or something like that or you just declare a variable.
    For example (assumed that data region is located at SDRAM):
    #include <stdio.h># include <unistd.h># include "system.h"
    int input_data = 1;
    int output_data = 0;
    int output_data_read = 0;
    int main()
        IOWR(&output_data,0,input_data); // write input_data to output_data with IOWR
        output_data_read = IORD(&output_data,0); // read it back from output_data to output_data_read
        printf("output data = %d\n", output_data_read); // printing on STDOUT
       return 0;
    Second: I would usually use IOWR/IORD only in cases where it can be neccessary. Like bypassing the data cache. Otherwise, better use standard C-coding for accessing memory.
    Philipp
    • Yogesh's avatar
      Yogesh
      How to use standard C coding to access memory as per your answer?
      I am having an array of data say 1,2,3...10. I want to write this data to FPGA memory( say address 1,2,3...10) using C code .
      How to do this ? Can you please provide a sample code to do the same ?
      Thankyou
      Yogesh
    Hi Teddy,
    Problem 1:
    Problem 2:
    Cris
