8 years ago
NIOS II BSP: Problem building the project; No such file or directory
Hi all,
I am trying to build a project. I manually added all the required files(copied) to the project after starting that project. But after every "Build Project" operation it is reporting: xyz.h: no such file or directory.
Please note that I personally added xyz.h file in the project and it is also visible in the Project Explorer.
Please note that I accepted everything default while starting this project. Added .sopcinfo and started project.
What possibly may have gone wrong. I read many similar posts, but the solution provided in then is not working for me.
Best warm regards and Thanks
Tahir
    --- Quote Start ---
    no in the user application project
    --- Quote End ---
    Problem seems to be solved. I re-indexed after BSP regeneration and before rebuilding the project.
    That solved the problem.
    Thank you sir. Appreciated your help.
    --- Quote Start ---
    did you add the path of xyz.h to the Nios II Application Paths?
    (right click the project -> properties-> NiosII application prop.-> NiosII app. path, then put the path to App. include dirs)
    Jens
    --- Quote End ---
    Thank for reply.
    Do you mean in the BSP project location?
    Jens
    --- Quote Start ---
    hello TAHIRSENGINE.
    how do you write the code?
    if you include the file with angle bracket.
    # include <xyz.h>
    you should change it with double quotation.
    # include "xyz.h"
    --- Quote End ---
    I did the same. Problem persists.
    Please note that it is not my own code and I am using somebody else code.
    hello TAHIRSENGINE.
    # include <xyz.h>
    # include "xyz.h"
