8 years agoNIOS II BSP: Problem building the project; No such file or directory
Hi all, I am trying to build a project. I manually added all the required files(copied) to the project after starting that project. But after every "Build Project" operation it is reporting: xyz.h...
8 years agoHello,
did you add the path of xyz.h to the Nios II Application Paths? (right click the project -> properties-> NiosII application prop.-> NiosII app. path, then put the path to App. include dirs) Jens
