8 years agoNIOS II BSP: Problem building the project; No such file or directory
Hi all, I am trying to build a project. I manually added all the required files(copied) to the project after starting that project. But after every "Build Project" operation it is reporting: xyz.h...
8 years ago --- Quote Start --- no in the user application project --- Quote End --- Problem seems to be solved. I re-indexed after BSP regeneration and before rebuilding the project. That solved the problem. Thank you sir. Appreciated your help.
