NIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a project I have inherited which kept the FPGA image in a ECPS64 and the software image in CFI. I have combined the two and keep them in the EPCS64. Works OK. I have been trying to get the remote update controller to work. I have put it into the core via SOPC and can read and write its registers via NIOS. I can also make it do a reconfig but it always seems to use the factory image. Has any one got a working example using the Cyclone III and NIOS II?
I use the following to read 2 of the registers... ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x4); ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x0); After power on both registers read 0. After reconfig command, register 0 = 1 and register 4 = 8 Any ideas please? Brain is starting to hurt!69 Replies
Ok I opened the new epcs_flash_boot_controller.hex file in quartus and
in Quartus process menu -> Update Memory file worked, however to start assembler what do I have to do ? I have none idea ! - Altera_Forum
Thank you superior_100, it worked.
Just have another problem, when I want to Update Memory Initialization file with Quartus processing menu, it doesn't to update the new Hex : Error: Project contains unresolved partitions Error: Unresolved partition "<Top partition>" Error: Quartus II MIF/HEX Update was unsuccessful. 2 errors, 0 warnings - Altera_Forum
Hi Julien92,
You may try "make CODE_BASE=0x0". A link is valuble, I think you will get what you want there: 3w.alterawiki.com/wiki/EPCS_bootloaders. Good luck! - Altera_Forum
Hi Chris,
To boot on the desired address for Nios application, I did exactly what you did but unfortunately when I use your sample in typing 'make' I have the error : "make *** [all] Error 2" ; whereas when I go to my directory where boot_loader.h is defined and I modified the EPCS_SRC_ADDR like superior_100 I have only generation of .elf files. Where is the problem ? - Altera_Forum
Hi Chris,
To boot on the desired address for Nios application, I did exactly what you did but unfortunately when I use your sample and I type 'make' I have the error : "make *** [all] Error 2" ; whereas when I go to my directory where boot_loader.h is defined and I modified the EPCS_SRC_ADDR like superior_100 I have only generation of .elf files, where is the problem ? - Altera_Forum
Please take a look at the attached sample. This was for Cyclone III; you may need some changes to make it work on other fpga devices.
- unzip the files in a new directory - open Nios II command shell and go there - change EPCS_SRC_ADDR in boot_loader.h with desired boot address for Nios application - build the custom bootloader, which generates a epcs_controller_boot_rom_A.hex file (simply type 'make') - replace the existing epcs_controller_boot_rom.hex file in your Quartus project with the newly generated one (thus removing _A) - select Quartus Processing menu, then Update Memory Initialization file - select Quartus Processing menu, then Start -> Start Assembler - the generated sof file will boot from the specified epcs address - Altera_Forum
Hi,Cris Could you please tell me how to generate my epcs_controller_boot_rom.hex with customized start address?
I only got *.elf files but not *.hex files by rebuilt boot_loader_sources directory using NIOS II command console tools, and the r_flash_ptr has already been set to my new start addrss. - Altera_Forum
--- Quote Start --- You can probably just put the boot code into a user-defined internal memory block, and point the nios reset vector at it. That would remove the problems of the sopc builder repeatedly substituting its own file. After all, I presume that is what happens anyway. It would also let you use TCM for the boot code (probably more useful for the JTAG block though since you are probably copying code to SDRAM and have an instruction cache anyway). --- Quote End --- Dsl, I am following what you suggested. My problem is that the EPCS controller does not give me a transmit ready signal (when I read the status register)and the bootloader gets stuck in the loop waiting for the flash to be ready. If you look at the object file dump, // Wait until controller is ready for a TX-char, then send it. tx_ready_loop: ldwio rf_temp, EPCS_STATUS_OFFSET (r_epcs_base_address) d0: 92400237 ldwio r9,8(r18) andi rf_temp, rf_temp, EPCS_STATUS_TRDY_MASK d4: 4a40100c andi r9,r9,64 beq rf_temp, r_zero, tx_ready_loop d8: 483ffd26 beq r9,zero,d0 <tx_ready_loop> stwio r_epcs_tx_value, EPCS_TXDATA_OFFSET (r_epcs_base_address) dc: 92c00135 stwio r11,4(r18) It is here where I am not able to move forward. I never get reach address 0xdc. Till this point I am fine. This is my flow I keep the bootloader on internal memory and upon finding that the boot is for application image, I load the bootloader to an on-chip ram. I reset the nios control to the bootlader and let it run. When i am debugging the bootloader (i access the on-chip memory and put return instruction at various location to see how far the flow runs), I get stuck in the above loop shown. Any help would be great. - Altera_Forum
Sorted. Used the settings in my previous post but instead of doing a make on the bootloader did a make CODE_BASE=0x0. Working now. :):) Thanks all for your help. - Altera_Forum
The meaning of SOFTWARE_OFFSET constant depends on your actual bootloader.
If this a 'true' offset probably the correct value would be 0x200000 rather than 0x400000 (i.e. the offset between fpga image and elf) But it could also refer to the free space offset from end of fpga sof image to start of elf, although this would be not recommended since this is not a well defined value. Other smart bootloaders (IIRC the default one, too), are able to automatically detect the end of sof image and start loading from there. Look into the bootlaoder code and find it out.
