NIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a project I have inherited which kept the FPGA image in a ECPS64 and the software image in CFI. I have combined the two and keep them in the EPCS64. Works OK. I have been trying to get the remote update controller to work. I have put it into the core via SOPC and can read and write its registers via NIOS. I can also make it do a reconfig but it always seems to use the factory image. Has any one got a working example using the Cyclone III and NIOS II?
I use the following to read 2 of the registers... ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x4); ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x0); After power on both registers read 0. After reconfig command, register 0 = 1 and register 4 = 8 Any ideas please? Brain is starting to hurt!69 Replies
It's like if the IOWR from my app code didn't act...
factory code :
IOWR_RU_Watchdog_Timeout_Value(0x1FFF0000 >> 17); IOWR_RU_Force_Osc_Int(0x1); // Force the internal oscillator as startup state machine IOWR_RU_Early_Conf_Done(0x1); // Force Early CONF_DONE what do I have to write in my app code to prevent my app code to go back to the fac mode while watchdog was disabled ? - Altera_Forum
Thanks for sharing.
I modified 0x5 by ((0x1FFFFFFF) >>17) to obtain upper 12 bits of 29-bit watchdog timeout value, ok now it boots on
my application software, but after awhile I go back to the factory software while I disabled the in the app code like in the code above. - Altera_Forum
Did it, enable the watchdog in the factory sof but now I can't boot on the application image I always stay in the factory image.
You must enable the watchdog feature in the factory software before triggering the reconfiguration; then you clear it in the application software. This way if fpga is configured but software doesn't start, the watchdog would reset back to the factory image.
When I erase my software_app.hex of my app code (second fpga image) I should boot on the software_factory.hex of my factory code (first fpga) by default,
but instead of it I stay in my second fpga image and nothing runs because I erased voluntarily software_app.hex, do you know how to solve this problem ? - Altera_Forum
Ok, get it cris72 :D
--- Quote Start --- What you're saying is that my two slaves ls_hdlc and remote_update_cycloneiii should have the same value of clock example ls_hdlc_clk, but the master ls_hdlc_clock_bridge, I don't understand what you mean like value of clock ? --- Quote End --- You should use ls_hdlc_clk for remote_update component, too. If you want to use slow_clock connect remote_update to the slow_clock_bridge master port. What's the problem? This is straightforward! You already have bridges to separate clock domains. What's the point in connecting remote_update slow_clock to different clock domain??? --- Quote Start --- In reality I've the error Nconfig actived --- Quote End --- nConfig is a FPGA input which is used to reset and trigger a reconfiguration! It's indeed controlled by an external component, then it CAN NOT signal any error.
