13 years agoNIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a projec...
13 years ago --- Quote Start --- What you're saying is that my two slaves ls_hdlc and remote_update_cycloneiii should have the same value of clock example ls_hdlc_clk, but the master ls_hdlc_clock_bridge, I don't understand what you mean like value of clock ? --- Quote End --- You should use ls_hdlc_clk for remote_update component, too. If you want to use slow_clock connect remote_update to the slow_clock_bridge master port. What's the problem? This is straightforward! You already have bridges to separate clock domains. What's the point in connecting remote_update slow_clock to different clock domain??? --- Quote Start --- In reality I've the error Nconfig actived --- Quote End --- nConfig is a FPGA input which is used to reset and trigger a reconfiguration! It's indeed controlled by an external component, then it CAN NOT signal any error.
