14 years agoNew Verilog/Quartus user
Hi everyone, I'm new to verilog/FPGA boards. I took a course last semester on them and found them pretty interesting. I didn't learn quite as much so I'm looking for two things. First of all, w...
14 years agoOnce you get through that book I also recommend reading this:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf This will give you an idea of how to structure your HDL to best map into an FPGA. Another thing I recommend you pay special attention to are the differences between synthesizable and simulation code. What you write in say a simulation testbench may not necessary work in real hardware. So if you learn the difference early on you won't get into the pitfalls that others seem to find themselves in. Quartus also has a templates menu option under the 'edit' menu that you can take a look at too for small examples of things like coding RAMs/ROMs, flip flops, math operators, statemachines, etc...
