15 years ago
Negative spykes on all internal signals in EP4CE15E22C7N
Hello.
I use the EP4CE15E22C7N device. (E144 package).
The only clock connected is 50MHz, 3.3V to one of the clk inputs.
The VCCIO connected to clean 3.3VDC, the VCCINT and VCCPLL to clean 1.2VDC and VCCA to 2.5V.
When i download the design and looking at internal signals with SignalTap, i see that all internal signals, when they are in '1' state (i even created an internal dummy signal whic isn't dependent on reset or clock), getting one-sample-clock-wide negative spikes. When the signal is at '0' state, it doesn't affected.
I over-checked all the decoupling capacitors and DC supply quality and they are good.
I can't see any chance of electric contention on the I/O.
I had checked the exposure pad (at the bottom) with XRAY. I can see that there is partial soldering paste there (about 50% coverage, maybe there wasn't enough solder paste at production stage...), but for my opinion, even 50% coverage is enough, doesn't it?
Can anyone suggest another idea how these spikes could be created?
    As a simple test, if you reload the Signal Tap recording with the "Read Data" button, do the spikes appear in the same position? If not, it's rather a JTAG signal quality problem than a real spike.
