8 years agoneed set_max_delay understanding
Hi all, Can please some one explain that what is set_max_delay and what will happen it if is used on two clocks to meet setup slack inside FPGA? Kind regards Mohsin
8 years ago1) Remember that the virtual clock is the clock that drives the upstream (input) device. It defines the launch edge while your 160 MHz clock is the latch edge. What clock speed is driving that device?
2) If it's truly asynchronous, just false path it. If it's not meant to be truly asynchronous, synchronize it with a register chain (at least two registers) and false path the input from the device port.
