16 years ago
Need help : implement Gigabit Ethernet
I'm new on this forum, so I hope that I'll be clear with my question.
I'm currently working on Cyclone III FPGA Development Kit with the EP3C120F780C7N.
For my project I have to etablish a communication between my PC and my board with the Gigabit Ethernet. I have to send to the board datas to configure a camera and then send the pixels to the PC for a display.
My PHY device is Marvell 88E1111 so I try since two weeks to configure it with RGMII interface.
My problem is that I don't know how to use the TripleSpeedEthernet 9.1 either with MegaWizard Plug-In Manager (how to link all the I/O) or with SOPC (where I'm a total beginner).
Can someone help me and explain me how to use these functions or how to begin (maybe a tutorial exists with v9.1sp1) to advance in my project ?
Thanks in advance.
    thanks for advice Daixi,
    i build the project without trouble but when i tried to run as "nios II hw", i didn't see some errors but that :
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Processor is already paused
    Reading System ID at address 0x10022C90: verified
    Initializing CPU cache (if present)
    OK
    Downloading 0C000000 ( 0%)
    Downloading 0C010000 (20%)
    Downloading 0C020000 (40%)
    Downloading 0C030000 (61%)
    Downloading 0C040000 (81%)
    Downloaded 314KB in 5.4s (58.1KB/s)
    Verifying 0C000000 ( 0%)
    Verify failed between address 0xC000000 and 0xC00FFFF
    Leaving target processor paused
    and nothing else happened on my board or on the console
    i have exactly the same with an "hello_world" project, maybe do you know what mistake i have done
    thanks in advance
    Start with the Simple Sockets Server example from the IDE and compile it. The board should get an IP address from DHCP and start a server you can access with Telnet.
    You can then change the code to suit your needs.
    thanks for your respond
    i made run the program "cycloneIII_3c120_dev_niosII_standard" on my board but then how can i can communicate between the host (i think my PC) and my peripheral (i think my board)
    1) i tried a "ping" request with the cmd windows but without an IP address, i can't have a response
    2) i absolutly don't know how to use NIOS II IDE with the .c I have, maybe a tutorial on this task can help me but the only one i have is for the utilisation of LED (not very usefull in my case)
    thanks in advance
    This reference design doesn't apply well to the Cyclone III kit. It uses a SGMII interface, whereas you have RGMII on the kit. It is better to download the reference design from the page I indicated, which will run straight out of the box.
