16 years agoNeed help : implement Gigabit Ethernet
Hello, I'm new on this forum, so I hope that I'll be clear with my question. I'm currently working on Cyclone III FPGA Development Kit with the EP3C120F780C7N. For my project I have to etabli...
16 years agoYou can try and debug the software and put breakpoints in the TCP/IP stack to find out what is happening but it will be more difficult than using signaltap in my opinion.
What license problems do you have? If it is just because of the Opencore evaluation window, you can start the Quartus programmer as a separate application instead of configuring the FPGA directly from Qaurtus. That way you can keep the Opencore window open and run Signaltap from Quartus.
