16 years agoNeed help : implement Gigabit Ethernet
Hello, I'm new on this forum, so I hope that I'll be clear with my question. I'm currently working on Cyclone III FPGA Development Kit with the EP3C120F780C7N. For my project I have to etabli...
16 years agoI can't find anything wrong... Is there on-chip memory in your project? If yes you can try and compile a memory test application (it is one of the templates) using a reduced C library, put the .text and .bss sections in the on-chip memory, and have it test the DDR memory.
It should tell you if there is a problem with your board.
