14 years agoNCO phase drift
I have an NCO generating a 60 Hz sine output. input clk = 10 khz phase accumulator precision = 32 bits angular resolution = 32 bits magnitude precision = 10 bits phase increment value = fixed at 25769804 It is a parallel cordic implementation. My problem is I get a phase drift over time. I am a new user and would like to understand this better. Any insight would be appreciated. Thanks11 Replies
To allow PLL locking in "finite" time, you should allow at least 0.5 or 1 Hz frequency adjustment, I think. The PLL filter has to be designed for a respective lock range in case of an XOR or similar phase detector without frequency comparison
I'm using mains frequency PLLs mostly with "hybrid" (ADC based) analog phase detectors, because typical power electronic related designs involve mains voltage measurement channels anyway.
